Linux WD laundry list
control panel:
*program settings
-can’t make height above sea level over 100
*ftp/internet
-the main on/off switch is determined by “light on or off” not word on or off
-things like show in system tray, show in taskbar are old win settings
-meter download doesn’t work
*webfiles
-clientraw.txt not made
*offsets
-most offsets don’t work
*sun-moon image
-is not created
*wunderground/weather for you
-links don’t work
-on button determined by lights not word on
*aprs
-cause program shut down
-links don’t work
view
*fwi
-doesn’t work
*auto scale graphs
-doesn’t work
*program error log
-doesn’t exist
*wundergound almanac
-doesn’t work
As requested, this is what I saw…
Linux RH 9.1 and RH 3.0 as
The above plus:
I am unable to get FTP uploads to work (direct connect).
WD hangs up after five or ten minutes and it must be killed and restarted.
version 3.1 is available from
(i.e the zip of the executable)
fixes alot of above, but I am still to do more work on the degress symbol issue
also, the control panel and view panel now looks like it supposed to…there was a setting incorrect, which is set wrong with the port from the windows version
Quick question on the Linux version. Does it support the new Flash/Live interface?
I believe that the only thing the flash uses is the clientraw.txt, which can not currently be made with Linux WD. But maybe if we ask nicely brian will take a look :wink:
actualy, it can produce the clientraw.txt file
tick to produce that in the ftp/internet setup, client/server setup
but I need to add in the extra data needed for the graphing for the svg viewer
and then the file will be updated in the webfiles folder (which you can set)
you are correct as always brian… that is odd, i never produced the clientraw.txt that way in the win verion, i always used the custome interenet settings, LOL you learn something every day :smiley:
