I have been running WD for a few years now and it is running well. However recently I installed another application and now I get a conflict when trying to restart WD after either logging out or redrafting my Mac Mini.
I get a conflict with a USB library driver I think libjack.dylib. The application is a program for debugging MSP430 microcontrollers mspdebug. I find I can’t run this application either. However if I reinstall WD, including drivers, reboot then restart WD and reinstall mspdebug without having to reboot both applications run fine until next time I restart the Mac! Fortunately this isn’t that often but using this process is a pain!
Sorry I haven’t got any more info but next time I restart I will get log info.
I don’t understand the low level details of the internals of the Mac, can anyone point me in the right direction to get a resolution to this problem?
Regards
Phil.
I created the library, libjack.dylib
but someone else has same named library
its not used normaly in WD, expcet if using a labjack
so I will remove it from WD for the Mac
once I get the power supply problem sorted on my mac so I can compile a new update
Thanks for the update. I didn’t know whether the library file was required or not. I am using the WMR-100, even with this I presume I don’t need this library file.
Will await your update. Other than this minor problem WD is running fine.
Regards
Phil.
Just to confirm my clash with the library I have just restarted my system and this is the error message I get:
Process: WeatherD [494]
Path: /Applications/WeatherD.app/Contents/MacOS/WeatherD
Identifier: com.company.WeatherD
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [331]
Date/Time: 2011-02-13 15:30:24.099 +0000
OS Version: Mac OS X 10.6.6 (10J567)
Report Version: 6
Interval Since Last Report: 802937 sec
Crashes Since Last Report: 5
Per-App Crashes Since Last Report: 3
Anonymous UUID: 67B018A3-4DCC-4066-B8A7-C7C9622AC7C4
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /usr/local/lib/libusb-0.1.4.dylib
Referenced from: /Applications/WeatherD.app/Contents/MacOS/WeatherD
Reason: no suitable image found. Did find:
/usr/local/lib/libusb-0.1.4.dylib: mach-o, but wrong architecture
Binary Images:
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) /usr/lib/dyld
Model: Macmini3,1, BootROM MM31.0081.B06, 2 processors, Intel Core 2 Duo, 2 GHz, 4 GB, SMC 1.35f0
Graphics: NVIDIA GeForce 9400, NVIDIA GeForce 9400, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x90), Broadcom BCM43xx 1.0 (5.10.131.36.1)
Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS545050B9A300, 465.76 GB
Serial ATA Device: PIONEER DVD-RW DVRTS08
USB Device: Keyboard Hub, 0x05ac (Apple Inc.), 0x1005, 0x26400000
USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x021e, 0x26420000
USB Device: SB X-Fi Surround 5.1, 0x041e (Creative Labs), 0x3042, 0x06200000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8216, 0x06110000
USB Device: Universal Bridge, 0x0fde, 0xca01, 0x04100000
USB Device: Generic USB Hub, 0x058f (Alcor Micro, Corp.), 0x9254, 0x04700000
USB Device: VF0640 Live! Cam Socialize, 0x041e (Creative Labs), 0x4083, 0x04710000
USB Device: USB2.0 Hub, 0x05e3 (Genesys Logic, Inc.), 0x0608, 0x04730000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000
Is this error message what you thought was my problem, if you remove reference to this library in the future will this correct the library clash I have?
My mspdebug application has obviously loaded another library of similar name.
If I reload WD, run it and then reload the mspdebug package everything runs fine until next restart.
Regards
Phil.
I have removed it in the latest .zip update
Hello Brian,
Thanks for the news.
Will download it and try it out.
Good to see you have got your Mac back.
Regards
Phil
Hello Brian,
Downloaded Build 77.
Still get the same error having loaded my other application.
See error dump below:-
Process: WeatherD [505]
Version: ??? (???)
Parent Process: launchd [325]
Date/Time: 2011-04-13 19:32:40.037 +0100
OS Version: Mac OS X 10.6.7 (10J869)
Report Version: 6
Interval Since Last Report: 1580716 sec
Crashes Since Last Report: 2
Per-App Crashes Since Last Report: 1
Crashed Thread: 0
Dyld Error Message:
Binary Images:
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x90), Broadcom BCM43xx 1.0 (5.10.131.36.9)
Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 1 incoming serial ports
To get WD running again I have to reload the library package from the complete build 60.
Not sure where to go from here. Anyway build 77 seems to be working fine for me by itself.
Regards
Phil.
that error report is nothing to do with libjack.dylib
but instead with the libusb
I suggest that you have a libusb that is not standard (i.e had been changed from standard)
as there is no other reports of this problem
