It is a community effort, all the way.
So yesterday I forgot to mention the needed changes or the new version on this forum. The problem was first discussed at WX and I posted the “change-link” solution there. I knew Ken would be awake in a few hours and as always modify the script for stand-alone and Saratoga use and post it even before his morning coffee. I tested the change and put the modified Leuven version on-line.
My question is:
Please always check the problems page first.
Write your post with while refering to the solution at the problems page
or
3 If there is no solution there,write your post and I will read it and know what to do.
If there is a solution, let people use the dwonload versions as not everybody is fluent in changing code. And it happens all to often that a 'simple" script change results in unnecessary support calls.
