For the mobi pages it is always the yr.no forecast as that one is worldwide available.
At the bottom op the forecast you see the location used. It is the default one from the download (Belgium/Brussels/Brussels/)
You have to modify the yr.no settings in wsUserSettings.php, see the remarks there.
I’m trying out the template and have gotten a lot of it to work. There seems to be a problem with the Overview part of the WxSim forecast display. Here’s the link to my unfinished site: http://www.dlewczyk.com/Weather/index.php?p=wsWxsimPrintFull&lang=en#data-area The temperature and precipitation amounts appear to be wrong. They are correct in the 3 hour interval and 48 hour detail tabs. The graph numbers are also good. Thanks for all the hard work you put in on this template. I never could have done anything remotely like this on my own.
thanks for the complements. I am abroad until Dec 21 without proper Internet.
Check wxsim settings for the units, they are in wswxsim/wxsim settings
I do it by head so the file name is probably incorrect. You will find there a list of UOMs
Now we have a weather Bulletin from Environment Canada…
Based on my settings,it should appear in the top warning on the template…I kno i played a bit in the canada folders but just to be sure,ive uploaded the original CANADA folder…but no chances,it remains green :roll:
could it be because its just a Bulletin and NOT an alert/warning that its not popping up ?
if I had a computer available and decent internet, I would confirm that probably.
But until Dec 21, it is impossible to check that as I am traveling.
All data retrieved is displayed so when I am home I will check if bulletins can be retrieved at all in the xml file.
Will be back with an answer Dec 22,
[quote author=zacken542 link=topic=61397.msg495106#msg495106 date=1450818013]
I am upgrading from 2.6 to 2.8 so far it’s very good
but I have some problem using Swedish special characters like "
Hello win…About my previous post…i did some investigating and found…
As a french user,i want my website to be in french and its normal…
In the warning box,when in french language,its appearing with french an english so, i tried to chancge these.
$validWarningTypes[‘statement’] = 0; changed to $validWarningTypes[‘Bulletin’] = 0;
so thas why it wasnt working for the advisory…
If we could hide those words Statement and Haute priority (its appearing in frenchglish hahaha) on the left part.it would be nice…or find a way to fully translate those
I converted the language file to UTF-8.
You should use Notepad++ (windows) to modify it in the future. Make sure that the editor understands to read the txt file as UTF-8.
One thing more I learned about how to use UltraEdit in Save as menu
Thanks !
[quote author=zacken542 link=topic=61397.msg495437#msg495437 date=1451313080]
Is it possible to have warnings from 2 areas?
I am in warnArea=SE025 but warnAreaSE029 is less then 5km from me
