Led sign Trouble
Could maybe someone post a screen shot of their led sign setup ,using customisation setting.
I’ve checked in the control panel and it allways says led sign connected OK,but nothing ever shows up on
the sign. It’s a Betabrite 213-c. It also works fine with the Betabrite software.Also serial conection.
Any help would be Great.
Bump!
Any help out their?
Mine is a Boshi Electronics (Wideled), but setup is quite simple:
Select the comm port to use, tick “enabled”, tick “enable customization” and write whatever you want in the text to appear box, eg: Temperature: %temp%. The result will be something like this: [color=purple]Temperature: 12
I have tried that many times, but for some reason it
never gets sent to my sign.
hi rhoag, any luck with this? also in the same boat. spent a few hours on this and cant get WD data to the screen.
