LED sign temp deg C query
i have been running my led sign ok with my wmr928
with my VP setup the %temp% displays present temp is as 3.40C, on the 928 setup this shows as 3.4 without the 0C, i use 1 of the graphics on the led display to show deg symbol C part
if i try %temp,% it shows as 3,4 + my graphic but the comm does not look right
what should the %temp% display
Harold
i have been having a play with this with latest build 38
the unit running davis vp2 setup has the led sign showing the centigrade temp as 4.30C should show as 4.3 i have a client unit running as stationless and this gives only 4.3
from this i have concluded the %temp% tag i use in custom text line should only show numbers with no letters after
this suggests that while in vp2 setup there is something causing the 0C to be added but i do not know where from
Harold
