Latest Build
Using build 77 for about 6 hours now without interruption :slight_smile:
Same here, 12 hours now.
Bertil
Installed the fresh build here today too, and at least so far seems to be reading the input data without stopping. I had noted though that even with the previous builds, the green data light would still flash when data came in the port, but WD just didn’t seem to be processing the data.
I have noticed quite a few instances of setup info not saving, and causing a hang though.
Just as a request, could we get a vers. update for the Mac version so we can see what has changed from build to build?
I set the dayssnow tag back to not reading the lg2.txt file (as per my other post saying that was the problem with the file permisions (and made the suggestion to remove the use of that tag ))
I’ll have to redact some of yesterdays comment on the latest build…the input data folded and everything flatlined about an hour later. The event log did not seem to offer an opinion…
