Weather Stations which can be sued with PWS_Dashboard should communicate either with a
- Weather-program => almost all “normal” weather-programs are supported
- Weather-net => WeatherUnderground, Ambient network, weatherflow and Weatherlink.com are supported. Ecowitt.net will be supported a.s.a.p.
- or communicate directly to the PWS_Dashboard such as ecowitt and or foshk-plugin
I think it is difficult nowadays to find a normal → excellent weather-station which data can not be read in one way or another
however my anemometer didn't record winds very much higher than a generally blustery day.
I "manage / take care" of 5 weather-stations.
The 3 on my appartement all recorded windspeeds of [b]74 +/- 4 km/h[/b]: Davis VUE, Ecowitt tri-wing, Tempest (ultrasonic) .
A Davis VP-2+ at my daughters house is located on a roof, large gardens, open areas, not to big trees [b]66 kmh[/b]
Another Ecowitt tri-wing [b]34 kmh[/b] on my sons place, urbanised area, small garden, lots of houses.
So the device to measure is only “nearly” as important as the location. Crowded location, less windspeed.
Has anyone used an Ultrasonic one? I like the minimal maintenance aspect,
The problem with the Tempest: it also recorded 35 mm of rain, all other stations mine and the official ones recorded around 2 mm.
Other users of the same Tempest devices confirmed they had similar quantities of "ghost-rain".
On the WX-forum similar "discussions" for the current Ecowitt ultrasonic ones.
For now ultrasonic wind recording seems correct for higher wind-speeds. Still discussions for lower wind-speeds.
Rain measurements are wrong both for very low, trickle rain. And totally-wrong with very high wind-speeds.
Middle of March my “Christmas” present will be delivered, an ultrasonic all-in-one Ecowitt-Wittboy.
It was available on KickStarter and I will mount it side-by-side with the Tempest and compare the measurements.
I expect its measurements will be more in line with “mechanical” stations as there is more and easier firmware and calibration
About the beta test a.s.o. there is a separate forum blog => WittBoy = GW2001 (station) = WS90 + GW2000 on Kickstarter & Beta test
As it is far above my budget, I hope someone will also answer for the Sonic Anemometer - SKU 6415 — Davis Instruments
P.S. The topic name does not mention pws-dashboard.
As @budgie said, this topic could be moved as attracting opinions works maybe better in Weather Station Equipment section
I can not do that, as I can only moderate the dashboard part of the forum.
