Lacrosse 2310 problems
Not a WD problem !
Our Lacrosse 2310 looses connection with the wind speed and direction meter. External temp is also out. This has happened twice the last two days.
The data does not show on the console either, just —
The only solotion seems to ‘reboot’ the Lacrosse console, and then it works again.
Anybody any experience with this ?
Kind regards,
Michiel
Search the forum for “LaCrosse” and/or “flat lining”.
This is a well known phenomenom and is well reported and discussed within the Weather-Watch community.
It relates to an interference / RFI / EMC problem that the LaCrosse PC/wireless receiver is susceptible to. I overcame this by obtaining and extension lead and locating the receiver as far away from the computer and other electronic equipment as possible. Also, adding a ferrite torriod or RF Balun to the connecting cable of the receiver can sometimes help.
Patience will also be required as it is a trial and error fix and can take time.
Bob
Thanks for your reply !
Does this also affect the wired solution ? We are not using the wire-less option, just all the parts hard-wired
Michiel
Michiel,
I also have a wired version and every month or so I get a flat line for wind speed and direction. It always comes back to life on its own after a couple of hours. We may both have RF interference problems as Bob metioned even with the wired version.
Take a look at this thread concerning shielded cable.
http://www.weather-watch.com/phpBB2/viewtopic.php?t=3058
I’m going to do this and see if it corrects my wind drop out.
John
yup, the shielded cable replacement has worked for people who do this
I told La Crosse about the fix months ago, and they said thanks…so if i were them, i would ship them with a shielded cable…
Thanks for the advice all,
The Foiled UTP option looks to be the only certain way !
I will have to get on the roof of the club-house : yes !
In the mean time, I have moved the console, it was placed between a thermostat and a USB ADSL modem, maybe that has something to do with it. Thats when the problems started.
I hope that will be enough
I will keep you informed
Thanks again for the prompt answers
Kind regards,
Michiel
www.zeilclubgavermeer.be
