Can someone point me to the KEEP LIVE box so I can kick start WD at midnight?
not sure what you are meaning
In one of the threads there is mention that the LIVE BOX needs to be checked if WD stops at midnight to automatically restart it.
not that I am aware of
what is the exact problem you are having?
which version and build?
Weather station equipment is Ultimeter 2100 connected via serial port.
WD stops recording the wind data at midnight or 3am on many nights. It is not happening every night as it runs fine for a number of nights then stops for some time and only a restart of WD will clear the problem until the next time out period.
Yesterday I updated the serial port driver and the version of WD and last night it recorded the data so I will give it some more time before asking for more help.
just windspeed or all data?
Wind speed and direction only. All other data is ok.
ah
there is a spike check in WD
and so if the windspeed spikes, WD will then ignore it…but that should reset
maybe try adding RF baluns to the cables?
which version/build of WD?
