Hi. I have just launched my own weather station, and I have used weather display live, which I have licensed. All the instruments Are working very well, but all the informations in the diagrams and the records Are wrong. Seems to be some default test data? There must be some files that not are uploaded perhaps?
I have now discovered that it is only clientraw.txt that is updated. The other clientraw*.* files Are not updated from WD?
I think my problem is that they are not updated.
I dont’t think it is the upload to web that is the problem. I have discovered that it is only clientraw.txt that is updated within WD, not the other clientraw files. This is somthing I have realized later. It must be the updating of the files in WD that is wrong!
Hi again.
Yes, I am running WD all time, 24 hours, never shutting it down.
It might be that this “cry for help” should be in another group, because, as I have said earlier, I can see that all the files are beeing uploaded to internett, but they are not beeing changed from WD!
This is the problem. It must be some settings that I have missed.
TYPE A
200 Type set to A
Uploading file c:\wdisplay\webfiles\clientraw.txttemp → markblomster.com/TFA clientraw.txttmp
PORT 192,168,1,107,252,225
200 PORT command successful
STOR clientraw.txttmp
150 Opening ASCII mode data connection for clientraw.txttmp
226 Transfer complete
File uploaded at time :17:37:55
RNFR clientraw.txttmp
350 File or directory exists, ready for destination name
RNTO clientraw.txt
250 Rename successful
