First and foremost, thank you goes to Stuart for his outstanding work on this!
On to my problem… All of the graphs work like champs but I can’t get anything to show up for the month_rain.php graph. I used the default file and my paths are obviously right or none of the other graphs would work. Any advice would be greatly appreciated.
Tony take a look at your clientrawdaily file, it appears the months rainfall for last 31 days is all zero. That’s where the info comes from, fix that and I think the graph will start working. It is offsets 63 through 93 for last 31 days rainfall.
Hmmm. That is odd. Why the heck would it not be there? :?
I wonder if it would have anything to do with the fact I just switched last week from an OS 968 to a VP2+? Does it take a while for the data to show up? We had a good rain since the switch and it is showing on the other graphs.
My month_rain.php is not working anymore either. Not sure why, it was working perfectly for the last year and nothing has been touched. Any suggestions?
the last 31 days data file you can recreate via action, convert wd logfiles to data files
(first though makes sure last months data file is OK (see under view, graph history))
I can confirm reality that I got .08" on both August 13 and 16th but my clientraw shows it as “Rain Month 03” and “Rain Month 06”. If I’m reading my graph correctly…it is showing .08" but on the wrong days.
Michael
UPDATE: I just updated to the last version of WD and everything started magically working again…
For some reason, my rain is doing the same thing once more. My WD Software graphs say that I got 1.031" of rain on August 25th. My 82007lg.txt logfile also says that I received 1.031" too. But, my clientraw file says that I only received .24".
I’ve tried to recreate the last 31 days data via recreate via action, convert wd logfiles to data files with no luck. How do I get my clientraw file to update and why/where does this .24" value come from?
