Since Brian is away… I thought I’d play with some javascript to see if I could get %feelslike% to work like I want it to…
Functioning code:
[code:1]
TestSince Brian is away… I thought I’d play with some javascript to see if I could get %feelslike% to work like I want it to…
Functioning code:
[code:1]
Testhi
so is not still not behaving? (in wd)
i.e if there is wind, the units are then wrongly converted?
but no wind its ok?
that will be the clue (no wind means its just set to the current temperature)
Hey Brian,
Check out this link:
http://www.weather-watch.com/smf/index.php?topic=5518.0
I think it’s the Wind Chill tag which is throwing off feelslike.
But you’re right. It seems to happen when there is no wind.
i have redone the feelslike tag
in a new 10.17v version
try that
