issues with sunposa.php
Hi from France
My website works fine since a few years, but I still have some issues that I can’t fix.
It’s all about astronomy page, which is almost complete, but the module “sunposa.php” doesn’t work.
I tried to download several versions of it, but I can’t make it work.
I use modified Saratoga’s Template for all my pages
http://www.plebraud-baobab.org
Here is the message you get:
http://www.plebraud-baobab.org/sunposa.php
Is there something I haven’t seen ? A kind of very stupid thing maybe…?
The image in your link display the error 25049 which occurs when either
  1. There is no font-file found at the specified location
    => there should be arial.ttf and arialbd.ttf in the jpgraph/ttf/ folder
    or
  2. the path to the ttf folder is incorrect in jpgraph/src/jpg-config.inc.php
    On line 39 (approx. as different versions exists) you find the define for the font to use:
    define(‘TTF_DIR’,‘/Applications/MAMP/htdocs/update/weather2/jpgraph/ttf/’);
You can use absolute addressing as in this example (the first / is your root)
If you have problems finding the correct path, use the small script attached.
  1. rename it to hardpath.php
  2. upload it to the jpgraph/ttf/ folder
  3. run it by http://www.plebraud-baobab.org/..../jpgraph/ttf/hardpath.php
    it will display the exact path to the folder.
Succes, Wim
hardpath.php.txt (29 Bytes)
Thanks. :wink:
I’ll work on it, I think some of my site’s folders look like big mess #-o #-o
(For instance, I have “jpgraph-2.3” and “jpgraph-3.5” folders, with different files in it)
I’ll be back for news
To wvdkuil…
First investigation, I already have arial and arialbd *.ttf files in the “jpgraph/ttf” folder
I think I need to focus on folder settings, maybe some mistakes around.
Here are my settings in “sunposa.php”
include (“graphsconf.php”);
include (“graphlang.php”);
include ($jploc.“jpgraph.php”);
include ($jploc.“jpgraph_scatter.php”);
include ($jploc.“jpgraph_line.php”);
include ($jploc.“jpgraph_date.php”);
$clientrawextra = get_raw(“clientrawextra.txt”);
Here are the settings in “graphsconf.php”
$hostloc = “./jpgraph/”;
$jploc = “./jpgraph/src/”; //must have trailing slash
Here are the settings in “jpg-config.inc.php”
define(‘TTF_DIR’,‘/homepages/42/d609300052/htdocs/jpgraph/ttf/’);
The folder “jpgraph” is uploaded at the root of the site
“graphsconf.php” is also uploaded at the root (so is “graphlang.php”)
For now, I still have the same issue message…
I admit I’m little bit confused…
http://www.plebraud-baobab.org/jpgraph/ttf/hardpath.php => displays: /homepages/42/d609300052/htdocs/jpgraph/ttf/
But the error message says the script is looking for /homepages/42/d609300052/htdocs/jpgraph-2.3/ttf/arialbd.ttf
Seems to me a “which folder is the one I shall use this time” folder-name issue,
Well, It’s weird…
My “jpc-config.inc.php” settings are:
Maybe the problem is here…
I got it !!
Simply, I create another folder named “jpgraph-2.3”, with a “ttf” subfolder, with the 2 “ttf” files in it…
It was just a real mess in my folder names and how to go to it…:roll: :roll: :roll::roll: :roll: :roll:
Thanks for your help, you make me awaked… :wink:
Now, I must work on my “thermometer.php” issue, but everything is fine on my website (I hope you like it)
Regards… from France…
Goodafternoon!
  1. I found a bug in diary plugin . If a month have zero percipitation then every day in this month diary displays “Day with highest precipitation of the month (0.000 mm).” .
  2. No translations work in diary ?
