Ip address weather Link Live
I have problem to change the ip address in weather display from the initial ip addres entered (192.168.1.102) to a new (192.168.68.54). When i enter the new address, it will not work but the “data received” flashes green and data is counting up but nothing happens with the data.
Also when i press “auto detect” nothing happens.
When i reboot the program, the old ip address is back again.
Of course I save every changes and updated to the last version.
Any input on this would be very much appreciated, it got me very much new grey hair:-)
Could be a problem of two separate subnetworks.
Questions:
Is the WD computer also on the 192.168.68.x subnet.
Are the WD computer and the WLL connected to different routers/access-points?
It all depends on the router / access-point which could block the data moving between the two separated parts of your local LAN.
You could test that by connecting the WD-PC to the same 192.168.68.x subnet access-point to which the WLL is connected.
Hope this helps,
