iOS 10 and iWD
Just to let you know that iOS seems to have broken something for iWD. Just get the startup screen and then it crashes. I know iOS 10 is beta but usually this is an indication of something is being changed
what about WDliveapp?
That is operating fine. I never used the iWD app before, and only purchased. Both my iOS devices are on iOS 10
the older iWD I am not updating anymore (as I lost the source code and key)
and so instead you can use the free WDliveapp :slight_smile:
Ah ok.
I get the same error when trying to run Iwd on my ios10 iphone 7s.
use the WDliveapp (free) instead
I just downloaded the new app and installed on my phone (10.3.2) and while the apps runs and I can get into setup. However I am getting no info being posted to the phone.
I have the URL To clientraw.txt set correctly and saved. Not sure what and if I need to set the 4 Bookmark locations.
Any suggestions as to what I am doing wrong.
Mike
what have you set as the url?
Hi Brian:
If I type in the URL below into my web browser, it gives me the data contained in the clientraw.txt
http://www.ve3yf.com/weather/clientraw.txt
I never put in the http:// prior to the www. When I put it in everything works fine.
Good stuff. What are the 4 Bookmark lines in the setup for. Tnx.
Mike
you can set other URL’s to other people’s clientraw data you want to easily check up on
