For some reason, WD has always had a problem with generating the web averages/extremes for December 2001. I tried it again today, and it again failed, but now I can see that there is an IO error 6 occurring each time I try to reset it. (From the program error log)
Another question - when I try to recreate the web Averages/Extremes for December 2002, it does not work either, and I get a program error log entry of “File Not Found”, and the web file contains no data.
The log file for December 2002 is in the log directory. What file is missing?
I select 12 2002 for the month. Progress bar moves 2 notches. Nothing else happens. I go to “View Program Errors” and see the “File Not Found” error. I know the log file for 12/2002 is there, I can view the averages/extremes for that month and correct them.
So then I tried 11/2002, 10/2002, 10/2001 - same problem. What folder does this reset function look in for the log files? How do you convert the list boxes containing 12 and 2002 into a log file? Something is broken here!
I cannot even recreate the origin IO Error 6 any more - the whole web reset seems to be broken for me!
9.44a Update - the program error log I now get is:
trends last month file= c:\wdisplay\datafiles\month122002.inf
ERROR: File not found at time/date 7:54:48 PM 1/9/2003
The inf and log files do exist:
C:\wdisplay\datafiles>dir c:\wdisplay\datafiles\month122002.inf
Volume in drive C has no label.
Volume Serial Number is 58B3-B349
I have the same problem and sent the december 2002 logfile to brian.
In the prgramm error log i can read: Error: file not found at time…
Now I use 9.44 c
hey, i plicked up the courage and took the plunge into the deep dark recreate averages/extreme routine in WD.
and there was only a few little things that needed tweaking that made all the difference!
uploading vers 9.45 now, that fixes this up
promise, I tested, and i actualy got my old december 2001 averages/extreme file updated!., and its looks perfect!
(note: it does take a while to complete, and burns a bit of cpu power!)
