This sub-board is for details of projects to build specific weather related IoT devices/systems.
If you are building an IoT project, create a new topic to hold the details. Please include details of what the project is intended to achieve, the hardware required, including where to source it from if possible, and add links to the software (if using source code from elsewhere) or attachments containing the source code/apps if you’ve developed them yourself.
Please also include your estimate of the skill level required to complete the project, e.g. a project requiring the soldering of a small multi-pin integrated circuit will require a higher level of skill than something that can be purchased as modules and plugged together.
You don’t need to have completed the project before starting a new topic for it. Projects in progress are welcome too. You might find that someone else is working on something similar and will provide information which may help you to complete your own project.
