Incorrect Sunrise & Set times
G’Day
Just got FreshWDL up & running.
I notice Sunrise shows as 01:11 & Set as 12:16
The data is coming from a WeatherFlow Tempest via a Meteobridge - the Tempest page shows Sunrise correctly as 06:40 and Set as 17:46
I also played with WeeWx which also gets its data through the Meteobridge - but shows correct Sunrise & Set times.
Any suggestions as to where to start looking…??
I answered your other post, where you mentioned ConsoleWD. . .
I have checked the ConsoleWD Lat & Long settings & they are correct.
As a reverse check- typing those values into Reverse Geocoding Tool Convert Lat Long to Address
comes up correct. They are also the same numbers I used in WeeWx and that works fine.
But FreshWDL still says Sunrise at 01:12 and Set at 12:15
The correct times are Sunrise at 06:44 and Set at 17:46
So I am still scratching my head…!!
Longitude E is entered negative in WD.
Solution was - As provided by Bitsostring - But WD uses astronomical lat/long, so 138.88E is entered as -138.88 (as the comment says).
