my machine is not running between 10.15 pm and 4.30 am.
At midnight there was a gust with about 50 km/h.
Today with the 1st e-mail weather report that gust was reported as “gust in the last hour”.
That problem seems also beeing with rain data ( but I had no chance for checking that since the first time I recognized, because of no rain in the last weeks between 10.15 pm and 4.30 am)
data extraction when starting wd in the morning works fine without any problems; there is also now entry in the prog error log.
Any ideas?
Cheers
Roman
it must be that the midnight reset/roll over is not being done from the data exctration
if you could email me the file vptemplog.txt
then i will check the dates/times from the extracted data
aslo, re the synop, i have forgoten to look at that, but also, i was away all afternoon today…
so i will check it out soon
it doesn’t matter …
I am at work now - I 'll e-mail the vptemplog.txt in the next time.
thanks for the good job.
Cheers
Roman
Just noticed I have a similar problem and found this thread. When I start up in the morning the ‘max gust last hour’ shown on the main screen is always the highest recorded from the whole archived data, so if the max gust was at 03:33:00 at 31.00mph then at 07:30 when I start up that is shown as the max gust last hour, it should be showing the max gust between 06:30 and 07:30.
