Importing data from Davis VP2 Very Slow! [Resolved]
Hey there,
Not sure if this is the new compiler or not but…
I had an issue causing me to restore data from the Davis VP2 back into WD.
It is taking painfully long to do this. Prior it used to zip through it.
Just thought I would mention.
Also single digits are not showing the 0 - ie. 01 shows as 1 etc
I made a video screen capture, but can’t upload .mov. If you want I can email it to you. It isn’t large at all
Also since writing this it is still importing. I want to say 15+ mins now for 10 hours of data to import. Prior this would take under 5 mins.
I did make a change so that you could see the 2nd stage better
but that does make it slower
I can change that back
Brian
What do you mean second stage?
What would be the ramifications of putting it back? i.e. what second stage would I be missing whatever that is
Also did you see the digit issue -nothing serious just mentioning in the minutes such as 01 02 etc it shows as 1 2
Im tempted to say back to old way where it was faster, as long as no sacrifice in data etc but will wait to hear what second stage is
Thanks again as always :slight_smile:
1st stage is getting data from the console
2nd stage is writing that data to the WD log/data files
latest update has it back to how it was now
Got it and installed it
Thanks again for your quick turn around on these things
Much appreciated
Had another flat line over night
So re-importing the whole night worth of data took a minute or so vs. 15+
Thanks Brian
