Image Names offsetting
OK, here’s another one (sorry for the flurry of posts; I haven’t played with WD in some while and I’m finding all sorts of things at once…)
Images that are uploading are showing up with the wrong names;
summary.gif isn’t showing up at all, though it is being produced (as trends.gif)
gusdial.gif, directiondial.gif, and averagedial.gif are all showing up as expected
These files are being saved with the correct name on the local hard drive; they’re apparently being renamed during the uploading process for some reason. I do have one of my custom pages set to rename whilst uploading - might that for some reason be carrying over to the graphics…??
Whilst this problem is occurring anyway, visible at http://mysite.verizon.net/vze7ij1o/CurrentC.html
Win98SE, WD 10.18f, Adelphia cable internet
check under view, ftp log, view full log, and you most likely will see a file not found errors
post what is there here
Here’s the “full log” dump:
list of files uploaded*
C:\WDISPLAY\webfiles\roundhill.html
C:\WDISPLAY\webfiles\wx.html
C:\WDISPLAY\webfiles\wx22.html
C:\WDISPLAY\webfiles\CurrentC.html
Start Time/date:15:12:25 10/20/04
Permanent connection selected
Checking for what else to do…
there are 2 more things to do
Wunderground connected status: OK
Wunderground complete
there are 1 more things to do
Aprs data sending now…
APRS Connecting to: 206.97.61.102
Aprs connected
sending pass command
user CW0146 pass -1 vers wx-display 10.18f 31
Sending the aprs data now
APRS data send:
CW0146>APRS,TCPIP*:@201910z3908.00N/07742.03W_047/000g003t052r001p002P0
02b10183h00.WD
Disconnecting from the aprs server now
APRS disconnected
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do…
Time/date:15:12:31 10/20/04
Logging onto FTP server…ftpmysite.verizon.net
Connecting to FTP server.
Connected.
220 ftpmysite.verizon.net
USER=****
331 Password required for gary.oldham.
PASSWORD=****
230-User gary.oldham logged in.
230 Quota: avail(4.2%)=440179.0 used(95.8%)=10045581.0 limit=10485760.0 bytes
TYPE I
200 Type set to I
Checking for next FTP agenda…
Doing ftp upload
Checking there are files to upload
There are more files to upload
PORT 192,168,1,101,9,244
200 PORT command successful
226-Transfer complete.
226 Quota: avail(2.3%)=246334.0 used(97.7%)=10239426.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,245
STOR roundhill.html
150 Opening BINARY mode data connection for roundhill.html
226 Quota: avail(4.1%)=432115.0 used(95.9%)=10053645.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,246
226 Quota: avail(4.1%)=427185.0 used(95.9%)=10058575.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,247
226 Quota: avail(4.2%)=436557.0 used(95.8%)=10049203.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,248
226 Quota: avail(4.1%)=428382.0 used(95.9%)=10057378.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,249
226 Quota: avail(4.0%)=414539.0 used(96.0%)=10071221.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,250
226 Quota: avail(4.0%)=421208.0 used(96.0%)=10064552.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,251
STOR wx22.html
150 Opening BINARY mode data connection for wx22.html
226 Quota: avail(4.1%)=430542.0 used(95.9%)=10055218.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,252
STOR CurrentC.html
150 Opening BINARY mode data connection for CurrentC.html
226 Quota: avail(4.2%)=438038.0 used(95.8%)=10047722.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,253
226 Quota: avail(4.8%)=503589.0 used(95.2%)=9982171.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,254
226 Quota: avail(3.8%)=402225.0 used(96.2%)=10083535.0 limit=10485760.0 bytes
PORT 192,168,1,101,9,255
226 Quota: avail(4.8%)=498728.0 used(95.2%)=9987032.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,0
226 Quota: avail(4.8%)=505822.0 used(95.2%)=9979938.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,1
226 Quota: avail(4.8%)=505984.0 used(95.2%)=9979776.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,2
226 Quota: avail(4.7%)=493472.0 used(95.3%)=9992288.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,3
226 Quota: avail(4.7%)=494943.0 used(95.3%)=9990817.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,4
226 Quota: avail(4.7%)=494334.0 used(95.3%)=9991426.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,5
226 Quota: avail(4.8%)=500018.0 used(95.2%)=9985742.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,6
226 Quota: avail(3.3%)=347998.0 used(96.7%)=10137762.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,10
226 Quota: avail(4.9%)=510131.0 used(95.1%)=9975629.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,12
226 Quota: avail(4.8%)=508266.0 used(95.2%)=9977494.0 limit=10485760.0 bytes
PORT 192,168,1,101,10,13
226 Quota: avail(4.8%)=506200.0 used(95.2%)=9979560.0 limit=10485760.0 bytes
ERROR: List index out of bounds (0) at time/date 15:13:15 10/20/04 agenda item:
doupload
the missing file in the upload is
wx.html
do you have a file called that in the webfiles folder?
i.e you most likely have the custom switch ON, but you dont have a wxlocal.html
or you have set to use wx.html in the specail file converison (do not use file names there that wd would use otherwise)
so, elminate wx.html from the upload list, or at least create a dummy file that is called that. or create at aleast wxlocal.html in the web files folder, then it should be ok
I have a wxlocal.html and a resulting wx.html in the webfiles folder; I have wx.html renamed as CurrentC.html for the upload process. I’m finding, though, that what’s happening is some other wxlocalnnn.html file is getting renamed to CurrentC.html instead of wxlocal.html being so renamed. I’m going to stop the renaming to CurrentC.html and see what happens…
where are you doing that?
if you are using the special file converison, then dont use any file names that wd would otherwise be using
set completly different local and remote filenames there
I was doing that under Setup, FTP/email/etc., Custom Web Pages. I told WD to rename the local file wx.html as CurrentC.html for upload. I have since cleared out that whole renaming section… now wx.html is uploaded as wx15.html and wx22.html (wxlocal15.html and wxlocal22.html exist in the folder webfiles) but wx.html isn’t uploaded at all… and the image names are still offset.
post the latest full ftp log here agian
Here goes:
Start Time/date:16:34:13 10/20/04
Connecting to mail server.
Connected.
220 out014.verizon.net ESMTP server (InterMail vM.5.01.06.06
201-253-122-130-106-20030910) ready Wed, 20 Oct 2004 15:34:15 -0500
EHLO oldham
250-out014.verizon.net
250-HELP
250-XREMOTEQUEUE
250-ETRN
250-AUTH=LOGIN PLAIN
250-AUTH LOGIN PLAIN
250-PIPELINING
250-DSN
250-8BITMIME
250 SIZE 8388608
AUTH LOGIN
334 VXNlcm5hbWU6
Z2FyeS5vbGRoYW0=
334 UGFzc3dvcmQ6
Y2F2YWxpZXIx
235 Authentication successful
RSET
250 Ok resetting state
MAIL FROM:[email protected]
250 Sender [email protected] Ok
RCPT TO:[email protected]
250 Recipient [email protected] Ok
DATA
354 Ok Send data ending with .
Email sent OK
Email sent OK
250 Message received: 20041020203415.OBPN25088.out014.verizon.net@oldham
QUIT
221 out014.verizon.net ESMTP server closing connection
Disconnected.
Connected.
220 out012.verizon.net ESMTP server (InterMail vM.5.01.06.06
201-253-122-130-106-20030910) ready Wed, 20 Oct 2004 15:34:19 -0500
EHLO oldham
250-out012.verizon.net
250-HELP
250-XREMOTEQUEUE
250-ETRN
250-PIPELINING
250-DSN
250-8BITMIME
250 SIZE 8388608
AUTH LOGIN
334 VXNlcm5hbWU6
Z2FyeS5vbGRoYW0=
334 UGFzc3dvcmQ6
Y2F2YWxpZXIx
RSET
DATA
Email sent OK
250 Message received: 20041020203420.JQRK2120.out012.verizon.net@oldham
QUIT
221 out012.verizon.net ESMTP server closing connection
Disconnected.
Time/date:16:34:24 10/20/04
Connected.
USER=****
PASSWORD=****
230 Quota: avail(5.7%)=601244.0 used(94.3%)=9884516.0 limit=10485760.0 bytes
TYPE I
200 Type set to I
Doing ftp upload
PORT 192,168,1,101,4,104
226 Quota: avail(4.2%)=444903.0 used(95.8%)=10040857.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,105
STOR roundhill.html
226 Quota: avail(5.7%)=594101.0 used(94.3%)=9891659.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,106
226 Quota: avail(5.6%)=589171.0 used(94.4%)=9896589.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,107
226 Quota: avail(5.7%)=598544.0 used(94.3%)=9887216.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,108
226 Quota: avail(5.6%)=590371.0 used(94.4%)=9895389.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,109
226 Quota: avail(3.8%)=400790.0 used(96.2%)=10084970.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,110
226 Quota: avail(4.5%)=468490.0 used(95.5%)=10017270.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,111
STOR wx22.html
226 Quota: avail(4.6%)=477965.0 used(95.4%)=10007795.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,112
226 Quota: avail(4.6%)=485309.0 used(95.4%)=10000451.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,113
226 Quota: avail(3.6%)=380756.0 used(96.4%)=10105004.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,114
226 Quota: avail(4.5%)=472492.0 used(95.5%)=10013268.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,115
226 Quota: avail(4.6%)=479532.0 used(95.4%)=10006228.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,116
226 Quota: avail(4.6%)=479775.0 used(95.4%)=10005985.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,117
226 Quota: avail(4.5%)=467278.0 used(95.5%)=10018482.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,118
226 Quota: avail(4.5%)=468476.0 used(95.5%)=10017284.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,119
226 Quota: avail(4.5%)=468117.0 used(95.5%)=10017643.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,120
226 Quota: avail(4.5%)=474376.0 used(95.5%)=10011384.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,121
226 Quota: avail(3.5%)=366817.0 used(96.5%)=10118943.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,122
226 Quota: avail(4.6%)=482924.0 used(95.4%)=10002836.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,123
226 Quota: avail(4.6%)=481059.0 used(95.4%)=10004701.0 limit=10485760.0 bytes
PORT 192,168,1,101,4,124
226 Quota: avail(4.6%)=479736.0 used(95.4%)=10006024.0 limit=10485760.0 bytes
ERROR: List index out of bounds (0) at time/date 16:34:56 10/20/04 agenda item:
doupload
wx.html is still in the list of files to upload
nothing has changed
email me your settings:
go action, back up registry entry now, then email me the files wdisplay.ini and wdisplayftp.reg from the folder databackup
After numerous restarts of WD (along with several hard crashes), the files are correctly uploading now, both the wxn.html files and the graphics, with the right names.
http://mysite.verizon.net/vze7ij1o/wx.html
good work gary
what was the trick?
have you tried out weather display live?
I wish I knew what the trick was! Had WD crash on me a couple times, did several voluntary (and a few involuntary) restarts, and voila, things were working as expected!
I downloaded the WDL trial version yesterday but haven’t had time to set it up and give it a try.
looking good gary, you even have a animated web cam in the summary image
have you seen where you can set to have time stamped web cam images (every minute), and then , when you hold down the left mouse button while scrolling along the graph, the web cam image at that time appears!
(and the 6 hour graph gives even better resolution)
now what weather station software can do that?
Very cool, no doubt, Brian!
re crashed:
how much free memory?
yeah, win98 not the best OS, especialy for memory management,…as wd is memory hungry
wdl:
http://mysite.verizon.net/vze7ij1o/wdlv2_05.swf
does start the flash movie, so thats good
try, though, in the config file, actualy setting the url to the clientraw.txt and clientrawextra.txt files
I’m watching it right now, in the low 300 mb of free memory, CPU usage fluctuating all over the place from 7% to 51% (using the Help/About in WD. I do have it freeing up memory daily. If I’m not messing with it, runs pretty reliably, crashes mostly happen whilst I’m trying to change something.
I’ve added the full URL of the client… txt files to the WDL config.xml file, no change. Page just takes a long time to load without any of the flash messages appears (like configuring… or data loading…) I’m not sure what’s up, setup seems pretty simple and foolproof, which is why I’m suspicious of Verizon.
I had the same problems using WIN 98 on an older PC
No longer any problems using a new PC with XP Pro SP2
There is a problem with your xml file. If you view it directly from your website in IE you’ll see -
m
The XML page cannot be displayed
Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later.
Whitespace is not allowed at this location. Error processing resource ‘http://mysite.verizon.net/vze7ij1o/wdlconfig.xml’. …
Round Hill Weather & Climatology
t:1em;text-indent:-2em"> 50
258
If you correct that all should be well
Julian
thanks julian!
gary, your an old hand at xml…
so you should be able to sort this out smartly hopefully :slight_smile:
(as you know, xml can be quite picky!
