Hi !!
Does anybody else have the problem with two icons in the taskbar when you start WD, and no matter which one I close WD is closed
Hi !!
maybe you have 2 versions of WD running
check task manager, processes (go ctrl alt del) to see if 2 weatherd.exe running
if so, then use:
http://www.weather-display.com/downloadfiles/startupman.zip
to find all your start up programs
Hi!!
Nop, there is only one WD running.
