re_thanks for the explanations ok so it is possible to work around the malfunction WU by running cron tasks following the installation instructions of the template? but do you also have to edit the files “34_cron_addtoyear.php” and “w34_cron_stationcron.php”? … for live data I use the WL 2.0 api
thank you in advance
Regards
You should run the w34_cron_stationcron.php every 5 minutes and the 34_cron_addtoyear.php at 23:55
The files will be created the first time the crons run.
The data will be loaded into the day file by the station cron.
The addtoyear will add 1 line to the yearly file and 1 line to the month file.
You normally never have to change any scripts.
In this case you should change your easyweather setting as in this screenshot.
thnx ok i just did cron job scheduling …
I find a file “today.txt” in my folder ./chartsmydata
I’m waiting for the execution of the cron at “23:55” to see
normally it should work
Regards
today.txt (254 Bytes)
A quick look at the scripts showed that the January release was using the single value “precipIntensityMax” instead of the current “24 * precipIntensity”. . . problem solved.
For those who already want to switch from WU to your own graphs-data,
I wrote a smal script to convert the WU_CSV file in chartswudata/ to the data as used in chartsmydata/
The script will get your wuID from the easyweather settings, read the chartswudata/wuID.txt
and outputs chartsmydata/2019.txt and 2019_08.txt
I have no access to a WU.CSV file with imperial units, so maybe some USA user would be so kind to test it.
The graphs at https://www.weerstation-herent.be/pws07/ now use the converted wu data.
You have to set the easyweather setting to use your own data
AND run the w34_cron_addtoyear.php at 23:55 every day
AND rund the w34_cron_stationcron.php every 5 → 10 minutes, but most of you already use that cron.
PLEASE remove the script after use from your pwsXX/ folder, it has to run only once.
A lot of us are missing one or more groups of multiple days of data in their WU-CSV files.
This weekend I will write a small script to search the WU-api-database for those missing days in the converted file.
_cvt_wucsv.php.zip (2.71 KB)
hello
thank you for the script i just did the test actually we found the files txt pr against in my case we return to the starting point … to go back, just delete the files in the folder “chartsmydata /”?
Regards
Not all problems are solved at WU, sometimes new problems arise also.
Your “old” WU.CSV contains data until July 25.
Your new WU-dashboard is missing far more days for July https://www.wunderground.com/dashboard/pws/ILORRAIN49/table/2019-07-1/2019-07-1/monthly
Also the August data is incomplete, missing august 12.
https://www.wunderground.com/dashboard/pws/ILORRAIN49/table/2019-08-1/2019-08-1/monthly
thank you for the script i just did the test actually we found the files txt pr against in my case we return to the starting point ... to go back, just delete the files in the folder "chartsmydata /"? RegardsThe version of the script I posted yesterday, only converts the WU file without adding missing data. So yes, only the available data until July 25 was generated.
The new version (planned for this weekend) of the script reads the WU-api and tries to add missing days. I was glad to test that new script with your ILORRAIN49 data.
Attached the chartsmydata/ folder with all available from the .CSV and the WU-api history.
The only days missing are 2019-07-27 2019-07-28 and 2019-08-12
Unzip the folder and move only the 2019.txt and 2019_08.txt to your website => chartsmydata/ folder.
@ALL
Very strange, it seems that the new data base has it flaws also. There are more and different days missing in the dashboard as in the .CSV
I do need some other wu_ID’s with missing data to test with.
Post or PM me your wuID if you have missing data in the .CSV which, in your opinion, was uploaded correctly to WU in the past.
chartsmydata.zip (7.24 KB)
@Wim
i made the correction on my site
thanks for the returns
it seems to be ok
I have another station MeteoLive ID_WU "ILORRAIN102"
I am installing the template for this second station
to be continued
REGARDS
_edit :
template installed for my second station
charts_WU same problem csv loads :oops:
http://seremange-meteolive.franceserv.com/pwsWD/index.php
thnx it seems to be functional at this stage enjoy …
good evening fto
rectified
i have just seen my colors are absolutely discordant (month / year) ??! ide. for my first site
I do not understand your remark.
What is your problem and is it on this site? http://valdefench57sgz.franceserv.com/pwsWD/index.php
The graph colours has always been this way. Maybe a small screenshot would help to clarify.
Discordant colours are those that are almost opposite each other on a colour wheel. In colour theory, a complementary colour is the one directly opposite of a colour.
I checked your website and I found an error in generating the files when using weatherlink.com
The values should be in imperial units, same as the data from wl.com, but they were in your default units.
To test, I regenerated the year and month files for ILORRAIN102
If these are correct, I will regenerate the ones for your first site also.
chartsmydata_ILORRAIN102.zip (6.96 KB)
hello
sorry for the confusion :oops:
affirmative for the graphics put i had not thought of WL since my datas were correct
thanks for the file ok the values are (finally) consistent
please opportunity to have those for my first site “ILORRAIN49”
have a nice week end
Regards fto
thanks for the file
OK relative to the graphics it seems to be good now except for those of the rainfall (month ! / year ??) for the 2 websites … unless otherwise stated !
best regards
The last original pop-up contained errors in the data as detected by @beteljuice.
He / she also pointed me to the correct source for that data, thanks =D>
I had to rewrite the script to remove the html warnings a.s.o.
It will display the current and 2 next meteor showers, sun & moon eclipse and now contains clickable links to the wikipedia descriptions and IMO calendar.
As test I run it at Leuven Home Weather Station (wf version) click the “meteors” link in the sun or moon block.
If anyone wants to test it, the script is attached. Always make a copy of the current script, just to be sure.
meteors_popup.php.zip (4.8 KB)
Looks good, Wim, but the translations don’t work
Wim, you can use my site https://pendulous-here.000webhostapp.com/ I haven’t had any data since 7/25. Do I need to do anything first?
Yes on purpose as not all languages had decent translations.
Translations will now work and caused by some remarks of @beteljuice I added more information. F.I. peak dates now show the period, not the first day.
Also the new pop-up look as with the UV pop-up, so without the “very contrasting” white borders
As far as I can see the script it is ready for use.
For those helping me with testing the script, at line 1512 one can set the current date to any value for this year.
Also test with either the debug console (w34_module_test) or with _test.php
https://pwsdashboard.com/pwsWD/_test.php?test=meteors_popup.php&lang=nl
Both will show the PHP errors and list the missing translations.
UPDATE: New zip, I removed typing error , missing translation in large texts should work
P.S., Back to the WU convert script, which needs some documentation #-o
meteors_popup.php.zip (5.14 KB)
. . . almost
