Hi I have new Huygens wifi station. Connecting via wifi to WU working just fine. I am try WD with stationless and checked just WU api data. Connection and received data working and receiving data for about 6 hours then WD stop receiving data. Wifi direct is not working. Then I must regenerate WU api key and WD receiving data for another 6 hours. Can that be solved for some reason please. I have installed the latest version of WD
Thanks in advance… Marco
try setting the WU api updates a bit slower
as WU might be blocking you
Aaa ok i have seting it on 16 sec. By default is 300 sec shoul i leave that so?
Hi, it is working now, thanks…
