Humidity settings in WD
I have been having a lot of problems with the humidity readings, I am just about pulling my hair out with the problem, when I go Control panel-offsets-humidity offsets I set the slope factor to zero (0) if I then go into the universal settings on the Control panel and ho to the humidity settings the slope is set to ten (10) if you then reset this to zero, save, then go back into universal setup then the slope has automatically gone back to ten, can anyone please advise.
Many thanks. :?
10 is apparently the default setting in the universal setup screen - but if you’ve made the change in control panel/offsets/humidity offsets and set it there it will use those settings. At least it does for me.
its set, but not re loaded, that setting
I wil fix that :smiley: :smiley: :smiley:
Many thanks for that Brian.
Geoff :smiley:
