My Humidex shows 0.0
which version/build of WD?
I thought you would know your program?
When you click on the link above, you will see WD10.37 Rb56
Cheers
Scirocco
it helps if that info is provided, rather than having to go search for it
thats all
try a new .zip update, ready now
I have Main Weather Display install file v 10.37R Build 56 installed. That is the latest- no?
Cheers
Scirocco
Oh, yeah. Got it now.
Downloaded, unziped in the wdisplay folder, restarted and it is the same. No change. The thing is when I start WDisplay, no humidex shows up at all. Then I hover over the graph, humidex shows up fine with a value and after a few seconds when the graph moves further, humidex shows 0.0
I have set to show humidex on the graph area and that is working
.zip and email me your settings files
Thank you. Which files do you require?
Cheers
There is an FAQ here which explains what to do to get this information for Brian.
Also, I think your problem is related to the Heatindex display problem in this thread: -
Hi Simon,
Thank you. I saw that (and that was the reason I updated to the latest version). But it did not fix the Humidex issue I have.
Cheers
Scirocco
fixed now for your particular settings
Perfect, thank you amigo.
Cheers
Scirocco
