HTTPS/LetsEncrypt: Cameras and FreshWDL disappears
Hey!!
I have enabled Let’s Encrypt on my main-page (www.stenbergs.no) and on my sub-domain-page (weaher.stenbergs.no), where I have two cameras, some graphs and FreshWDL. stenbergs.no is ok with https…but problem:
When i substitute Http with Https on the sub-domain-code I loose both the cameras and FreshWDL. (As for now I have got it back to Http and weather.stenbergs.no is now ok). I have not yet tried to change code in the cameras. How to fix Fresh?
I’m not near my laptop at the moment but I seen to remember there being a URL for you site in the FreshWDL config. Have you changed that?
A https website is not allowed to show frames with http content.
All data/images/frames should be https.
Error messages in the browser:
Mixed Content: The page at 'https://weather.stenbergs.no/' was loaded over HTTPS,
but requested an insecure frame 'http://weather.stenbergs.no/FreshWDLmaster.html'.
This request has been blocked; the content must be served over HTTPS.
but requested an insecure image 'http://89.10.232.106:88/CGIProxy.fcgi?cmd=snapPicture2&usr=gjest&pwd=gjest123&t='.
You can use the webcam software in WD, then set WD to upload the image.
This is what I do
Yes &Thank you. Line 2 in FreshWDLmaster needs to be changed to HTTPS.
I have been working mostly with my Foscam-cameras. They seems to have problems with streaming over HTTPS. Right now i’m in a dialog with Foscam-support who suggest using proxy.php scrips like: https://Weather.stenbergs.no/proxy1.php.....While working on it I roll back to HTTP.
Thanks. Yes I see Mixed Content. Foscam-cameras seems to have problems with streaming over HTTPS. Right now i’m in a dialog with Foscam-support who suggest using proxy.php scrips like: https://Weather.stenbergs.no/proxy1.php.....Still-pic. ok but not streaming.
Working on it and for now I have rolled back to HTTP.
Thanks for your reply. I have never tried WD’s webcam-solution. I saw your solution, which is nice. But you don’t stream? I got a new picture each minute from your camera by asking, but i want to transmit live-streams and I dont know if that is possible in WD. I also have two cameras,
I see you also have Foscam. I have tried Foscam support USA with no success. They just say the certificate does not work. But right now i have a dialogue with Foscam support Oslo. They suggest using php-proxys like: https://weather.stenbergs.no/proxy1,php.......working on it.
Do you know any Foscam-cameras that livestreams over HTTPS?
