When I close my pc before midnight, the next day it still have readings before midnight(if I close it after midnight its ok),
in the picture you can see that, now its 08:25.
How can I have normal readings if I have to close my pc before midnight?
In Units and other settings / hour to reset daily high low values. What time do you have set - it should be 0 for midnight reset. You can reset the hour to any hour you want, you could set for 8.00 reset or 21.00.
I don’t want to change the midnight reset-this is the normal-I just want to have readings even if pc closed during the night(WD to download all the data from wmr200 data logger when I open pc in the morning…just like pc working all day long.
the data extraction routine from the wmr200 should still do the daily reset, as long as the midnight time is found in the data
(make sure 1 minute logging interval set)
this worked in my last test of this with my wmr200
which version of WD?
10.37M, do you mean 1min on the console?
which build number?
and yes
build 09, also changed logger from 5min to 1min.
