How to setup jpgraphs and wxgraphs
Well I am very happy with the advise you have been giving me! :slight_smile:
I
Check your PM for something that may help :slight_smile:
:multi:
Hi again!
Solved 2 problems :slight_smile:
  1. I had to CHMOD /jpgraph/ and subfolders to be able to execute PHP in them. I just set them to 777
  2. hardpath.php does not give my accounts real php path, I needed to login in to admin panel at the web hotel to find the path.
With the correct path in both scripts WX Graphs test works fine WX Graphs test page
But still empty popups in Steelseries http://www.gudmundsbyn.se/vader/steelseries/gauges-ss-basic.htm
First I thought that I have to define /wxgraphs/ in gauges.js or gauges-ss-basic.htm but I can
The graph location is defined in gauges.js:
        imgPathURL        : './images/',
sigh … I searched for wxgraphs and a setting for location :slight_smile:
should this point to /wxgraphs/ ? ie imgPathURL : ‘/customers/7/d/e/gudmundsbyn.se//httpd.www/wxgraphs/’,
and should I leave oldGauges as it is (since I don
It wants a relative path, I think that would be:
'../../wxgraphs/'
I don’t know what old gauges is, maybe a link to WDL ? I doubt it will break anything.
“It’s Alive!!!”
Thanks for all the help & patience with a PHP n00b :slight_smile:
Expect huge transfer of Karma points to your account :wink:
Looking good :smiley:
I have a strange problem.
The Steel gauges looks allright with the graphs from wxgraphs in IE11 and MS Edge. But when browsing with Chrome or Safari, the graphs are not shown, and gauges disabled (marked false in gauges.js) are also displayed in Chrome and Safari. It seems like gauges.js is not read competely in Chrome and Safari.
See http://ovlinglia.com/wgauges/web_server/gauges-ss.htm
I don’t see those problems, your gauges and graphs are working OK for me in Chrome.
Have you tried clearing the browser cache in Chrome and Safari?
Managed to get it set up, but curiously all the graphs on the test page appear to be using the default font apart from the Snow graph, which appears to be using arial. Any ideas?
http://www.costa-mogan.com/weather/wxgraphs/wxgraphs_test.html
This was an error on my part. I will take a close look at the snow.php file and provide a modified version in a day or so. It’s easy to forget when changing so many files.
The corrected version of the snow.php graph script is shown here simply copy and paste this into the snow.php file you have now and it should obey the font settings in the config file.
<?php
// Graphs Package V3.0 21st November 2016
if (!file_exists("graphsconf.php")) include("error_msg.php");
include ("graphsconf.php");
if (!file_exists($jploc."jpgraph.php")) {
  $string = "Unable to find JPGraph files";
  create_image1($string,$jploc);
  exit;
include ($jploc."jpgraph.php");
include ($jploc."jpgraph_bar.php");
$clientrawextra = get_raw ("${hostloc}clientrawextra.txt");//for this graph we only need the values from this file
// Here we create an array of the values we need depending of the month we are in (each month we shift to the left 1 place)
$x=array();
$y=array();
$y=array($clientrawextra['479'],$clientrawextra['480'],$clientrawextra['481'],$clientrawextra['697']);
$datay = $y;
if ($snow_conv != 1) {
	array_walk($datay, "SMtoI");
//With this-one we calculate the labels for the x-axis
$curmth = date("n");
$x = array($txt_today,$month_array[$curmth],$txt_season,$txt_depth);
// Create the graph. These two calls are always required
$graph = new Graph($xsize,$ysize,"auto",60);
$graph->SetScale("textlin");
//Setup margin color
$graph->SetMarginColor("$margincolour");
//Here we set a dropshadow around the graph
$graph->SetShadow();
// Adjust the margin a bit to make more room for titles
$graph->img->SetMargin(30,30,30,40);
// Create a bar pot
$bplot = new BarPlot($datay);
//Setup width of bars
$bplot->SetWidth(0.7);
// Setup color for gradient fill style
$bplot->SetFillGradient("$snow_col","#EEEEEE",GRAD_LEFT_REFLECTION);
// Use 10% "grace" to get slightly larger scale then max of
// data or the value of max will end up in the title area
// you can commend this out if you dont show the values themselves
$graph->yscale->SetGrace(10);
// Create a line plot
$graph->Add($bplot);
$bplot->SetWeight(2);
$bplot->SetColor("$snow_col");
if  ($bar_snow == 1) {
    $bplot->SetValuePos($bar_pos);
    $bplot->value->Show();
    $bplot->value->SetAngle($bar_angle);
    $bplot->value->HideZero();
    $bplot->value->SetColor($barTXT_col);
    $bplot->value->SetFormat("$snow_format");
    eval ($bset);
//    $bplot->value->SetFont(FF_FONT0,FS_BOLD,6);
    eval ($bsetv);
// Setup the titles
eval ($tset);
$graph->title->Set("$txt_snow ($snow_unit)");
$graph->title->SetColor("$textcolour");
//x-axis
eval ($xtset);
eval ($xset);
$graph->xaxis->SetTickLabels($x);
$graph->xaxis->SetTextLabelInterval(1);
$graph->xaxis->SetPos("min");
//$graph->xaxis->SetFont(FF_FONT0,FS_BOLD,8);
$graph->xgrid->Show(true);
$graph->xaxis->SetColor("$xtextcolour");
//y-axis
eval ($yset);
//$graph->title->SetFont(FF_FONT0,FS_BOLD,10);
//$graph->yaxis->SetFont(FF_FONT0,FS_BOLD,8);
$graph->yaxis->SetColor("$ytextcolour");
$graph->yaxis->HideTicks(true,true);
// Display the graph
$graph->Stroke();
I have updated my wxgraphs.zip file to contain the new version of snow.php, so any new downloads will get the updated file.
https://weather.scottsworld.info/wxgraphs/wxgraphs.html
Up and running, but all the values are metric except wind which is in MPH. I know nothing about php, I can code html and css.
Two of the solar files
generate this error. Would it ber possible to have the same UV files as the solar.
The error log showed it did not like UTC-7 for timezone but gave the error with a date America/Denver so I tried America/Phoenix but it did not seem to understand that so I changed it back to Denver which Phoenix is MST time but does not follow daylight savings.
#1 Fix the solar errors by getting the arialbd.ttf file into the location in the error message. That file should be found in the jpgraph download but is maybe in a different folder, or I’m sure there is one on your PC that you can use.
#2 All the units are set in the graphsconf.php file starting around line 80. Open it in any plain text editor, it is well commented, you should have no trouble finding and setting the units.
#3 Arizona time zone is problematic, I need to research that some more.
After skimming though other messages I looked farther into the config file and got the units changed. Will try the fonts tomorrow, the tv is my monitor for the weather station… Any hints on getting …/gauges-ss-basic-inc.php working? I had SS guages working, then WD crashed and I could not get it to work any more. linking php files
<img src="baro_1hr.php"
was something I did not know until I looked at the test page.
WD doesn’t provide separate graphs – the JPGraph set of scripts are used to display the mouse-over graphs when Weather-Display is used.
