MegaMaxPosts: 1
Future meterologist/storm chaser.
good to see a young weather enthusiast, welcome
MegaMaxPosts: 1
Thank you to both of you.
I see this is a very old thread, but I’m following the instructions nonetheless to install.
I’ve tried everything I can think of but getting a repetitive error:
Strict Standards: strftime(): It is not safe to rely on the system’s timezone settings. You are required to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected ‘Europe/Berlin’ for ‘CEST/2.0/DST’ instead in /homepages/44/d119568937/htdocs/website/weather/jpgraph-4.0.1/src/jpgraph.php on line 395
e.g. http://www.hssc.net/weather/wxgraphs/windgust_1hr.php
And here are my PHP settings:
The warning is telling you to add a time zone setting line, like this:
date_default_timezone_set('Europe/London');
Be advised that a new version of JpGraph was released a few days ago (2016-08-09) - version 4.0.1 of JpGraph supports PHP5 (PHP 5.1.0 or higher version) and PHP 7.0.
Thanks R_o_b, good to know
Hey - great - thanks - I’ve only gone and got it working!!
Hi guys!
Yet another newbie with jpg-config.inc.php problems …
Hardpath is /customers/7/d/e/gudmundsbyn.se/httpd.www/jpgraph/truetype/ http://gudmundsbyn.se/jpgraph/truetype/hardpath.php
http://gudmundsbyn.se/jpgraph/truetype/arial.ttf and http://gudmundsbyn.se/jpgraph/truetype/arialbd.ttf exists and are readable.
I have tried http://gudmundsbyn.se/jpgraph/src/Examples/testsuit.php with:
define(‘TTF_DIR’,‘/jpgraph/truetype/’);
define(‘TTF_DIR’,‘/customers/7/d/e/gudmundsbyn.se/httpd.www/jpgraph/truetype/’);
define(‘TTF_DIR’,‘${WEBROOT}/jpgraph/truetype/’);
with no luck fonts are not working.
I hope one of you spots my mistake or has a good idea re what I can try to fix this …
Thanks in advance /JensB
Try
define(‘TTF_DIR’,‘…/…/truetype/’);
or
define(‘TTF_DIR’,‘…/truetype/’);
Hi! Thnx for helping a n00b
Tried both, no luck
What version of jpgraph?
Version: 4.0.1 (2016-08-09) jpgraph-4.0.1.tar.gz
I’ve never ventured past 3.5, I’ll have to look at that one.
Please attach a copy of your jpg-config.inc.php saved as jpg-config.inc.php.txt
I set up what I think is the same directory structure and
define('TTF_DIR','../../truetype/');
works for me :dontknow:
so many weird things … sigh
when unpacking jpgraph-4.0.1.tar.gz with winrar on win7 I have to run winrar in Admin mode … because some file in the tar is seen as a symlink by windows. This results in the whole tar being unpacked again in jpgraph\src\Examples over and over.
Seems like the culprit is jpgraph a zero byte file in /Examples/
Deleted everything and started over now almost nothing works http://www.gudmundsbyn.se/jpgraph4/src/Examples/testsuit.php
Only thing I have changed in jpg-config.inc.php is the define(‘TTF_DIR’,‘${WEBROOT}/jpgraph4/truetype/’);
Also found out that I can
jpg-config.inc.txt (5.89 KB)
I used 7zip to unpack it, had no issues.
In my experience you have to work through this step by step…
First, change the foldername from jpgraph4 to jpgraph, jpgraph4 may cause some confusion and we have enough already :lol:
Next, start with http://www.gudmundsbyn.se/jpgraph4/src/Examples/accbarex1.php change these two lines:
require_once ('jpgraph/jpgraph.php');
require_once ('jpgraph/jpgraph_bar.php');
to
require_once ('../jpgraph.php');
require_once ('../jpgraph_bar.php');
and see if that graph works.
http://www.gudmundsbyn.se/jpgraph/src/Examples/accbarex1.php
nope not working
<?php // content="text/plain; charset=utf-8"
$datay1=array(13,8,19,7,17,6);
$datay2=array(4,5,2,7,5,25);
// Create the graph.
$graph = new Graph(350,250);
$graph->SetScale('textlin');
$graph->SetMarginColor('white');
// Setup title
$graph->title->Set('Acc bar with gradient');
// Create the first bar
$bplot = new BarPlot($datay1);
$bplot->SetFillGradient('AntiqueWhite2','AntiqueWhite4:0.8',GRAD_VERT);
$bplot->SetColor('darkred');
// Create the second bar
$bplot2 = new BarPlot($datay2);
$bplot2->SetFillGradient('olivedrab1','olivedrab4',GRAD_VERT);
$bplot2->SetColor('darkgreen');
// And join them in an accumulated bar
$accbplot = new AccBarPlot(array($bplot,$bplot2));
$graph->Add($accbplot);
$graph->Stroke();
same error when unpacking with 7zip 64bit (
something is wrong with permissions maybe?
hardpath.php works in http://www.gudmundsbyn.se/jpgraph/truetype/hardpath.php
but not in http://gudmundsbyn.se/jpgraph/src/Examples/hardpath.php
I don
I’m sorry, there’s something very wrong with all this and I don’t think I can be much help
