How to get WXSIM EWN-style scripts working under PHP5.3
Recently I got my WXSIM version customized by Tom and I wanted to use the EWN-style WXSIM-forecast scripts downloaded from NordicWeather (from 03-2017).
I am running my website on a Synology NAS with an old PHP5.3 version.
The WXSIM saratoga and Leuven scripts needed only configuration but to get the EWN-style scripts finally running I had to do the following:
  1. debug with browser URL …/wxsim-ewn/wxsim/_test.php?wunit=kmh&lang=en&test
  2. to be able to read the lastret.txt file I had to use an absolute path in config.php:
    $path_to_lastret = “http://leonas.ddns.net/Wetterstation.Suttenbrunn.CumulusMX/lastret.txt”;
    the relative path #path_to_lastret = “…/lastret.txt”; did not work
    although for the rest of the paths I could use relative path names:
    $path_to_langfiles = “./wxsim/”;
    $path_to_dataphp = “./wxsim/”;
    $path_to_js = “./js/”;
    $path_to_css = “./css/”;
  3. on the other hand to avoid a display of 01.01.1970 I had to use an relative path in script frc.php:
    ‘.UPDATED.’: ‘.date($timeFormat,filemtime(“…/lastret.txt”)).’
  4. to display a correct “next Update” I adapted the following line in frc.php:
    $thishr = date(‘H’); (replacing ‘i’ by ‘H’)
  5. and finally I had to adapt the sunmoon.php script to run under PHP5.3:
    a) replacing brackets by array () in some locations and
    b) harcoding the timezone in
    function fromJulian($j) {
    if (!is_nan($j))
    $dt = new DateTime(“@”.round(($j + 0.5 - J1970) * daySec));
    $dt->setTimezone(new DateTimeZone(‘Europe/Amsterdam’));
    return $dt;
Now the EWN-style interpretation of my WXSIM forecast is working fine under URL:
If somebody is interested I could upload/attach the modified php scripts.
regards
leo
and 6) take care that timestamps in lastret.txt are multiples of whole or half hour: 20:00, 20:30, 21:00, …
and not 19:50, 20:20, …
so that parsing of the file with data.php does not get interrupted
this can either be achieved automatically during WXSIMATE/WXSIM import (e.g. when also importing local data) or by adjusting Time Field in WXSIM main screen after import before starting the forecast calculation.
