Sorry I am going to de-rail this topic, but keep it relavent too, How do I get my current picture from the HP10 (Ecowitt server) downloaded (preferably using Weather Display, or a PHP call from my webserver) The whole issue of making a animation for me is not such a big thing as I have software and scripts to do that. I am sure getting the image from the Ecowitt server is probably very straight forwards but for the life of me right now I am missing it
Thanks I know I am probably being very dense. but I do appreciate the answers
Marcus
Hi!
Just use http://hp10-ipaddress/capture to download the current picture.
Oliver
Hi Marcus,
Local LAN solution:
As said before by olicat and myself, if you have WD running in the same local network, you already have the best solution to get the latest HP10-picture.
Locally you can see and load the image using http://local-hp10-ipaddress/capture
AFAIK most weather-programs can fetch a webcam image if there is an URL available.
I myself use Meteobridge for that, check here TEST TEST Home Weather Station (ecoLcl version).
If there is no recent weather-program in the same LAN as the HP10, it is less simple.
Solution 1: Your hosted webserver needs to load a picture from your home-network.
Steps to take:
- Open a port f.i. 5050 in your router which points to the HP10-device.
- Use a small cron-script on your website to load the image and save it somewhere on your website.
- The script uses an URL similar to the LAN one, f.i.
http://111.222.333.444:5050/capture
- The router will replace the external IP:port part with the local IP:80 → and forward the request to your HP-10 which will sent back the image to the script on your webserver.
- Use an allowed age of 5 minutes for the image or more to not access your home network too often.
- Adept the PWS-settings to point to the saved image.
Solution 2:
Load the image from the ecowitt server. For that you have to get an API key and write a more complex script which should
- Fetch the “weather-data” of your HP10 as documented by Ecowitt. That data contains the URL to latest image
- Then fetch the image and store it on your webserver.
