How to add extra or replace standard weather-values - clarification
My Davis Vantage Vue which I use for one of my PWS dashboards has a duff humidity sensor.
I successfully used the extra sensor upload file to replace the humidity value from another sensor. Now wanting to replace other values - dewpoint being the main one.
What is the syntax for this?
|humidity|hum| is the example given - would Dewpoint be |dewpoint|dew|
Edit: I realize dewpoint is calculated - I am using a meteobridge that seems to have a logical sensor with the data.
Guy
Hi Guy,
Next time, please post a link to your PWS_Dashboard website.
Now i had to scan your old post to check which weather-program you use.
Dewpoint is a “temperature-type” value.
The line in your extra upload file should look like
|dewpoint|temp|[thXdew-act:--]|!
Replace the X with the correct sensor number.
0 is the default outtside temop/hum sensor
But you could also modify the lines in your main upload file.
Then you do not have to use an extra upload file
Lines 3-5 in your realtimeMB.txt read
[th*temp-act:--]
[th*hum-act.0:--]
[th*dew-act:--]
Replace the * with the correct internal MB-sensor number
Readme
https://www.meteobridge.com/wiki/index.php/Templates
But you can also let your Meteobridge do the mapping
Readme and scroll to mapping
https://www.meteobridge.com/wiki/index.php/Select_Station
There is an example of using th1 (second station) as the th0 (primary station)
But you can also use an extra th sensor of a primary station.
@ ALL Best wishes for 2024
My apologies and thanks! Will make sure I post that (I did know).
I was more focused on the syntax of the first part of the statement and not the specific weather program used.
Guy
