If it’s not a trade secret can you share how WD interfaces with the labjack? Is the labjack’s own software running and putting out a file for WD, or does WD access it directly via USB, or none of the above?
Seems to be a really attractive device, pity it’s not directly ethernet instead of USB.
its a direct interface (via the usb (the labjack has drivers you need to install), using code i was able to directly put into wd, available from them
