How do I add the set-up buttons on the bottom of the WDL? I would like it so the that the viewer can change the way that they look at WDL. One other user has this feature…that moves the information around the WDL area. Any suggestions?
Not quite sure I understand the question. Can you post the URL of the site that has the arrangement you want then I should be able to help.
Julian
I hope this helps. I thought after I should have put this here. I would like to show the buttons that say “live weather 1” “live weather 2” etc.
thanks
Ah OK. What he’s done is just setup different web pages each pointing to a different config file. The buttons to choose are not part of WDL but are just normal html links.
Julian
