I have slowly added some 1wire sensors into my weather setup. Im using a honeywell TE923W weather station. I have 3 extra temp/hum sensors set to channels 2,4,5 and a extra temp sensor set to channel 3. They are communicating fine with the honeywell console but when i look under view->extra honeywell sensors the data is incorrect. This has occurred since I added a 1wire temp/hum sensor and set that as my main station temp and humidity. Could there be a setting i set somewhere that has deativated the ability to use the honeywell extra sensors? Thanks for you time.
Willy
