EDIT by wvdkuil 2021-02-03 09:30 UTC: MOVED to a separate topic, is of interest to others also.
(Re)reading messages is useful for the learning curve.
But sometimes raises questions …
Wim,
In Reply#30 of this thread you state
Your tempest, nor your 2 WU sites (IOVERIJS101 IHENGE37) use a weather-program, so (nearly) no history.
When it would have had rain history it should be displayed.
True that Tempest and IHENGE37 have an upload to WU only since November 2020, which limits the archive to just 2 months.
Upload to WU for IHENGE37 is direct from Domoticz.
Upload to WU for Tempest is by the Weatherflow-server, using their link-function.
IOVERIJS101 is being uploaded since 2015, and at the website checking the WU-history for any date since 2015 gets display of practical data.
That upload combines a data-stream from meteo-software WsWin with a datastream from Domoticz.
Same datatream from Domoticz is also feeding MetOffice/WOW and PWSW.
Therefore the short question ([i]for understanding[/i]):
[i][b]why[/b][/i] your statement that no history is present at WU which is usable for PWS_Dashboard?
There are two different “historical” data sets, one for graphs and one for missing high-low values.
The graphs do not have a “realtime update”, those data lags behind as it is often calculated with a low frequency by the data-provider.
This data can not be used for realtime-high-lows, because of number of API-calls, caching by provider(6 hours for WU-daily history) a.o.
There are currently two sources for graphs data:
If you set to use the WU data for graphs AND your station XXXXXXXX uploads to WU
THEN the scripts will use that WU data (if the api-key is valid), the data is cached in pwsWD/chartswudata/ and pwsWD/wudata/
All graphs will be available for the periode the station was uploading to WU (start-date has to be set in seetings)
One can update/ remove errors in the local WU-data (pwsWD/wudata/ ) using pwsWD/_wu_upd.php?pw=12345
If you choose to NOT use WU-graphs data => you need to run a cron-job which
THEN will create the local data-files for the graphs , the data is cached in pwsWD/chartsmydata/
The graphs will be available for today/month/year periods.
Data is saved every cron-run for “today” and every 00:00 run for month and year.
“Real-time” history for high-lows:
The small history.txt file with a “high-low for day/yday/month/year” is used in some blocks and a pop-up
The file is important for those stations which only have realtime values, such as the weather-nets, ecowitt a.o.
That file is also updated by the cron-job.
The live-data script uses the history-txt plus the last-measurements to show “near realtime” high-lows.
One can generate a “start-history” using WU-data. => pwsWD/PWS_hist_recreate.php?pw=12345
One can update the history file if is has an error-value in it => PWS_hist_update.php?pw=12345
Trust this answers your question. No need to answer.
Thanks!
Graphs no problem, because I use setting WU_graphs, and WU_setting is valid.
History_low_high needs some work because of enabling cronjobs.
Useful hints for ‘flying start’ of history!
MVG, Anton
Only 1 cronjob at 5 minute interval is needed.
Provider-cron normally use an archaic interface xyz/abc/php7.7 /home/user/whatever/pwsWD/PWS_cron_stationcron.php
Most errors occur in setting the correct path and using the same PHP version as your website is using.
Also sometimes the owner of the cron-job is a different one as the owner of the website itself.
Nearly all external solutions are better than using the cron-server of your provider, who sometimes even charge for that “feature”.
External cron-servers use the wget/browser format such as “yourwebsite.com/pwsWD/PWS_cron_stationcron.php”
Free external cron-jobs at:
https://www.cronjob.de/ in German
Free cronjobs - from minutely to once a year. - cron-job.org (Kostenlose Cronjobs - von minütlich bis einmal im Jahr. - cron-job.org in German)
Multiple others also when using Google-search
Multiple weather-programs (WD, Meteobridge) are able to schedule 5 min http request => identical to a cron.
Also https://pwsdashboard.com/documentation2012/11_cron.pdf
Interesting solution
Also very easy job for Domoticz.
No need to activate ‘something else’, but just a few more scriptlines …
