I am trying to refine my web page and need some assistance.
- I have used the tag %daysTminyear<0C% to try and show the number of days the temperature is below 32 degrees.
%heatcolourword%…How hot/cold it feels at the moment, based on the humidex, used with the conditionscolour.jpg image (which is updated with the gizmo.gif)
%daysTmin<0C%…Days where the minimum temperature went below 0oC
All available tags can be found in the file named owntemplate.txt located in the subdirectory where WDisplay is installed
This FAQ might help with adding NOAA warning to web page…
http://discourse.weather-watch.com/t/9695
You can also find them online at…
http://www.tokaanuskihire.co.nz/wdhelp/custom.shtml
In fact… bookmark this page:
http://www.tokaanuskihire.co.nz/wdhelp/index.shtml
I refer to it often!
I tried the tag %daysTmin<0C% and it still shows the tag and not the number of days.
I was using the reference to the tags you mentioned but I overlooked the one for the heatcolour.
Any ideas?
Tom,
face=“Arial”>%daysTmin<0C%</td
editor messed up " < "
Similar to this problem…
http://discourse.weather-watch.com/p/85980
Beat me to it Gus -
I had the same problem with that tag when I started with Tom’s template.
I was using NVU to edit the template, and it threw the same thing in the code as it did for you.
The only solution I have is to open the page in notepad, fix the tag, and you should be OK.
Thanks for all the help.
