help wanted. new web page - no wd
Hi all. I ahd wd running on my hosted site woodyswoodwork.co.uk - woodyswoodwork Lähteet ja tiedot. and it went to the public-htm dir.
I set up a sub domain of woodyspembs.org.uk
I changed the upload directory on WD to relfect the new directory address as follows. http://woodyswoodwork/woodyspembs.org.uk/weather
but all I get is either the root dir www.woodyspembs.org.uk/weather where you just see idex of … and the file headings, or if I make it the same but with.htm on the end I just get a blank wordpress page template.
what am I doing wrong guys, plesase
cheers woody
You would need to change the upload directory to something like:
/public-htm/weather
or /weather
or weather/
Your host should be able to tell you which is correct.
Quote from: JaxWeather on [b]Today[/b] at 08:53:32 AM
/public-htm/weather
or /weather
or weather/
It was originally posted to the /public-htm/weather but that was read by the old site, so i moved it thinking the new site wouldnt know how to read it. I guesss somehow (goodness knows how) I’m going to have to put it back and change the uploda dir back, then get the new site to read it from the original location:-(
woody
That’s not a proper URL - there are too many / - is it how you really have it set up? It also looks like you’re uploading to the /weather directory, so that http://www.woodyspembs.org.uk/weather/weather.htm actually works. If you just upload to www.woodyspembs.org.uk without the /weather on the end, I’d assume http://www.woodyspembs.org.uk/weather.htm will work as planned.
