This is a weird problem, I had a short power failure to the computer upon which I run WD.
With power restored I fired WD up and horror of horrors the main screen was devoid of all data, talking serious to it did not help, so I reinstalled WD again (Ver 10.37Q Build 34), all fields still blank, so I sat down and spent a considerable time to set up WD from scratch ( lousy job) and set up all the colors and screen settings, mm not bad, took aspirin and soon felt smug again. That was yesterday, today I closed WD down to allow me to make my weekly image of the disk!! that done I restarted WD it started with all data fields showing data Grr… all the color settings etc had reverted to some previously ordained scheme. the settings of the colour scheme I had so carefully chosen and set had vanished.
Can anyone out there tell me what I did wrong, why did WD not save them, and how do I fix it.
I thank you in advance.
I would invest in a UPS power back up
sudden power cuts can mean data loss
going action, convert WD logfiles, click on convert, then also click on recreate last 31 days data should have got your graph data back
also using a backup copy of your last wdisplay.ini file would get your settings back too
simple as that
THANKS BRIAN,
Please advise me how to ensure that I can save the new main screen changes I have made today?
There’s a save button on the same screen where you enabled changing it.
- Jim
