I am trying to put together a (tags) list with data about maximum average windspeed. Three of these tags do not work, and I cannot find the correct tags. Anyone any suggestions? The problem is with the tags that are in bold and have arrows pointing at them.
TODAY
%maxavgspd%
%maxavgspdt%
YESTERDAY
%maxaverageyest%
%maxaverageyestt%
THIS MONTH
%mrecordhighavwind% <<<<<<<<
%mrecordhighavwindday%
%mrecordhighavwindmonth%
%mrecordhighavwindyear%
THIS YEAR
%yrecordhighavwind% <<<<<<<<
%yrecordhighavwindday%
%yrecordhighavwindmonth%
%yrecordhighavwindyear%
ALL TIME
%recordhighavwind% <<<<<<<<
%recordhighavwindday%
%recordhighavwindmonth%
%recordhighavwindyear%
Thanks!
If the tags are documented in the WD tag list file then you should email Brian to ask for it to be fixed assuming you are on the latest released version of WD.
I think the values have a different tag name format. An old forum message suggests they are:
%mrecordwindspeed%
%yrecordwindspeed%
%recordwindspeed%
Chris is correct. You can see the tags in the tagslist.txt file (attached) that’s in the C:/wdisplay folder.
tagslist.txt (168.4 KB)
This is it indeed. Thanks!
However good WD is in what it does, it’s too bad tag names can be so inconsistent
