Hi have webpage working only when i manually upload, not uploading automatically, any help greatly appreciated.
Using WMr200 and WDL
website http://homepage.ntlworld.com/stuart.cox/weather/
Not sure if I have settings right.
Have you got the clientraw.txt files uploading?
If you have then you should see a yellow & grey box in you PC’s task bar that occasionally has a red up arrow on it.
If you’re not seeing this then you need to start it, there’s an FAQ about it HERE but due to server updates the images in the thread seem to be missing at the moment.
If you’ve been uploading the file manually then I assume that the main screen is setup, that being the case then all you need to do is go to: Control Panel > Web Files/Web Page/FTP/WDL > Real time client ftp /SVG / Weather Display Live Setup. Once on this screen, make sure that the switch on the top right of the page is ON and then click “Start Now” and you should see the yellow/grey box appear in you task bar.
See how you go with that and come back if you have any problems.
Hi have done that and this is what I get.
ERROR: 11004: [11004] Valid name, no data record (check DNS setup) at time/date 19:51:21 23/11/2008
Any suggestions, many thanks.
Is the main Internet switch ON in Control Panel > Connections and have you filled in the Server Settings part on that screen?
yes, make sure you have set the ftp server in the connections setup in the ftp/internet setup
also if you have ticked to use this server instead, in the real time ftp setup, in the webfiles/web page setup (not normaly used), then makes sure you have the ftp server set there correctly as well
Thanks for all your help, up and running fine now.
what was the probem?
(to be able to help others in case they had the same problem)
