HB UV sensor upcreep
My Hobby Boards UV sensor’s readings keep creeping upwards. I already subtract 1.5 units from the reading, but it’s back up to showing a UVI of 0.5 at midnight.
Is the sensor deteriorating? Is the temperature compensation not calibrated correctly? Has anyone else noticed this?
interesting that the Davis UV sensors seem to suffer the same problem
must be some deteriation of the sensor that occurs over time
I noticed that the overnight UV readings were getting lower again. Hmm, he said, temperatures are getting warmer.
I went back through my records for the past few weeks looking for correlations between the night-time UV reading and the temperature. There is a very definite correlation. Colder temperatures produce higher readings.
So, perhaps the temperature compensation needs to be reprogrammed. I know that there is some user-settable temperature compensation. I’d have to read up on what, if anything, I can do to adjust this.
