A short while ago I updated my forcast pae for the new weather undergound changes , all was working ok until a couple of hours ago but just checked now and have this message on the page
Sorry.. this country forecast can not be processed by this script.
Locations in the United States and territories should use the carterlake NOAA script.
Locations in Canada should use the Environment Canada forecast script.
If this was a working non-USA, non-Canada forecast, then it is likely that WeatherUnderground has changed website design and you need an update to the WU-forecast.php script to handle this changed design.
I’ve had this problem on & off, and I found that if I deleted the WU-forecast.txt cache file it resolved the issue by fetching a fresh forecast. I also noticed that the normal size of the WU-forecast.txt file is around 224kB, whereas the one that produced the error was only around 180kB, don’t know what the difference is though.
