GW2000 Dailyrain not seen in WD
Just connected an EcoWitt GW2000 with WS69 sensor to Weather Station for Windows. Everything works fine except rainlastmin and dailyrain that is not read.
If you look at the data log you can see the data is present:
eventrainin=0.031&hourlyrainin=0.012&dailyrainin=0.031
But it is not stored in WD. Note that rainfall month and year is working.
Any ideas?
Thanks //Lars
Topic title says WS2000, post says GW2000?
Not sure if this helps, but there is a setting in crongw1000 (which runs in the background) for Wittboy/GW2000 in use.
Sorry, I fixed the typo in the subject.
OK I see now, I used the “Customized Server option” but when turned that off and used crongw1000 I now get the correct rain data.
Thank you very much for help!
