I am running an Ecowitt GW1000. I have added a water sensor. I am using the local IP of the GW1000 and can see that it is finding the sensor and tracking the value. It’s seen as “USR1 17.5C 63.5F” in CRONGW1000. I cannot find this in WD. What is the variable in WD for this sensor?
In WD under file - setup -advanced, there is a tab for ecowitt you need to fill in the details there so that it picks up from ecowitt.
Thanks, I’ve filled the top part of the screen in - and can see other devices (anemometer, rain gauge, indoor temps, etc.)
I’m not using the API at this point (maybe I need to?).
The CRONGW1000 program is running and I see it as “USR1” but I don’t know where to observe this in WD.
unless you are using the ecowitt api to upload the info it wont show up in WD under extra sensors
