I used to use this graphweather and now i decided to try it again, but i cannot for the life of me
get the darn thing to output to the graphs…
I followed Pinto’s advice on the graphweather forum but its not worked, I know a few on here used
to use this program and im hoping some still are and can help me out…
I have a customtextout.txt file currently at 100mb
Hi pinkpanther, thanks for the reply, luckily i have kept a backup of the graphweather folder
and just copied it over and reinstalled the latest version and now its working, sadly though, having checked
the customtextout file, at some point WD had (for some strange reason) decided to change the customtext
file to 3 variables only, must be default or something and i have lost over a years worth of data, from
Jan 2010 to now basically, pretty gutted about that…
Just out of interest, is there a way to rebuild the customtextout file?
I don’t think it can be rebuild automatically, depends what you want to do, you can use the log files instead, if all the info that you want graphed is in the log files. Just copy - paste all the log files to one file.
You have to change the setup of graphweather to match the log file order.
