Graphs
can WD be configure not to show the graphs on the right side of the display? I know I could adjust the wind size to cover, but would prefer on the current conditions on the left to be shown.
keith
no it cant
but you can move the graphs off screen via the main screen customisation
not sure why you would want to do that , myself
Brian
WD takes space on the screen, when I have my ham logging software open, I like to keep an eye on only the current conditions, as this will determine if I need to reduce the hight of the antenna mast. historic info is not needed, just current.
Keith
you can set to have them moved off screen and or make the WD window not as wide
Brian
many thanks, I will give that a try.
Keith
