Graphs for SteelSeries mouse-over
I’ve been digging around, and haven’t yet figured out where to set this up. The mouse-overs/tooltips on the base SteelSeries page clearly has places for graph histories of each parameter. How do I configure WeatherDisplay to output these? I’m pretty sure that I’d seen that at some point, but have not yet been able to find it. Can anyone help me out?
-Charlie
The graphs are the jpgraph wxgraphs described here.
If you use forum advanced search (hit the magnifying glass symbol to the left of the search box at the top of the page) and select to search only this SteelSeries Gauges forum for wxgraph or graph you will find a number of threads that will be helpful.
That’s great! Thank you so much. I’ve got it working now, is it difficult to add extra graphs? In particular, I’d like to add last hour graphs for my extra temp 1 and extra temp 2. Is this trivial, or does it require lots of digging?
I could be wrong but I don’t think the extra temp last hour data is included in the clientraw files that are the data source for those graphs. If not then you could set up a custom logfile in WD and create a similarly formatted jpgraph using that as a data source. That would be a decent size hole to dig, but it wouldn’t need a backhoe :wink:
Thanks! I’ll have to look into that when I get some free time here! I appreciate your help.
-Charlie
